EwOkIE
Everything posted by EwOkIE
  1. Merry Christmas all
  2. Anyone?...
  3. If posible can please show there AGV lids on there heads ie: side view, front,rear etc Mine :
  4. Had an email from AGV say they cant replace the D Ring with longer style but I can move the clasp... so good result. Will give it a try soon to let the pads wear down a bit and see if I can get to the clip/clasp ok....flippin freezin ootside!!!!!
  5. Maybe give the helmet to me brother then
  6. The nerve...saying I'm ugly with a big nose, surely!
  7. I know thats why I like it checked the rating before trying lid on...safety first. So is this plausible to do with the chin strap (removal guide I posted)
  8. J&S Store closest to me is Hamilton 15 mins Read this not sure though : Chin strap removal
  9. Was thinking what if I go to a tailor and ask to put one of the clips on the right side of the strap (longer one)..will this be ok?
  10. HI is this what you are referring too : Image for illustration This is just on the left side. the strap is simple enough to get in the rings just the clip. I have an old helmet kickin about was going to see if its possible to adapt that to this if possible. Got the helmet new for £89 with black visor. So if possible would like to try and do something with the strap. But dont want to lose my head Do the straps come off the helmet, how do they attach onto the helmet themselves?
  11. Thanks for the reply Is it possible to lengthen the strap, maybe get adjust by a tailor about an inch or two? As I like the helmet and the only 2 things are the tip of my nose touches the nose guard (can live with that) and because I am used to a chin curtain on my xlite feel as though my chins under the helmet a bit (maybe I am getting old)
  12. Hi as the title suggests I have a query regarding an AGV Stealth Helmet. I have read numerous sites on checking/measuring head size and correct fitment etc. I am 54cm and would say round head Going with AGV Site it recommends the XS Helmet....so went to check out some helmets Tried a few on, as I Have an Xlite 801RR which is a small I tried a few of AGV's Small Stealths on first... quite a bit of movement side to side, tried the XS on ..no probs. On the XS my nose just touches the nose piece (not sure of technical term) and the chin strap is quite a bit to the left, is there a way of adjusting this as its the Double D with the clip? The clip itself once I have helmet on and through the loop the clip is hard to get at, nearly hidden.. If anyone has had experience with this or know of a solution please let me know. As I like the style of the helmet and when I first seen the XS thought to myself aint know way this is going on my head looking at it...but fits good
  13. No joy on just the bush! Going for this as this is whats been recommended to me : 285-530-16 215-530-46HA Tsubaki Alpha 'X' Ring Drive Chain 530APX-108
  14. OHLINS - the one you can turn by hand, clicks! Not sure which way is soft or hard (no funny comments now)
  15. Thanks for the info, so DID or EK is the best chain. what about sprockets, any recommended ones. This ok for the front : Renthal 16 Tooth Ultralite Front Sporcket. The Renthal part number is 285U-532-16P I use the bike all the time and have some fun at the weekends ..so needs to be fast. any help on the preload adjuster. Thanks again.
  16. Hi all, right I am in need of new sprockets and chain but dont know what to go for These are the choices I have )-Rinf or X-Ring Chain ?? O-Ring Chain (never heard of) 1st Choice 2nd Choice or ....this one and.... an AFAM Set sprockets and Chain (520 Race) ,,,what does that mean?? Whats best for my bike. Soooo many choices.. Also.... the OHLINS Preload adjuster (which way do I turn this) Thanks
  17. Yes Its the piece that goes onto the item pictured , like a bush/collar. Picture
  18. Yes the valve/bush that the exup valve slides into. Tried various sites with no joy, is it necessary to have this as when I take the valve ot I can see the hole where the end of the valve should go into, cant I just grease it up??
  19. Hi does anyone have or know where I can get the bush that connects to the exup valve below the manifold. Just the bush itself that needed. Thanks Tried wemoto,fleabay with no luck..
  20. Hi, dont want to cut into any wires or harness, just need the LED if anyone knows on where to get this in the UK. As all I can find is the US but they want a big order to ship them to here. Thanks
  21. Hi reason why I am asking as I fitted the LED's all round the bike, flash rate is ok just that they all flash at the same time like hazards. Dont want to fit resistors/diodes just to replace the dash light. As I took the bulb out to make them flash correctly just now. So dont have indicator warning light on dash at the minute. Thanks
  22. I stay in the UK and am looking for non polarised led, tried maplin with no joy and american companies want an order over £15.00 to ship them. Help please.
  23. Yamaha YZF 750 R (1995) 26K - Silkolene Super 4 Semi Synthetic (may change to Mobil Super S)
  24. Right this is where i am at, tried to take out dash lamp to see if indicators would work. But didnt have the patience to remove the screen to get to the screws behind clocks. You mentioned fitting a resistor to each of the rear indicators, which resistor do I need or would this do : Resistors for indicators I heard that IN5402 or IN4007 would do it, but checked online and found out there diodes. Thanks
  25. I am currently looking for a Chain Guard for my bike but without the hugger (Silver preferably tried Puig) Also does anyone know if the rear lights on this bike could be replaced with aftermarket ones, if so could you let me know as these look terrible. Before I purchase a set of K&N Bolt on air filters for my bike, has anyone else seen any power or drop gains by doing this and is it worth it. Lastly, is there any hi level exhaust brackets for this bike. Thanks
