Runningdog
YOC Member
Everything posted by Runningdog
  1. Runningdog replied to drewpy's topic in The Bar
    Received mine on November 25......post mark said it was sent from Manchester On November 22.....3 days to go from Britain to rural Canada...unbelievable. Looks great, will have a proud spot on my old leather jacket.
  2. Runningdog replied to a post in a topic in Classics
    Nice bike...I just sold one. Lots of common parts with the '77 and '78 DT400, but not so much with other bikes. Many parts are still available from Yamaha or aftermarket suppliers. Oldgitonabike is very knowledgable about these, hopefully, for your sake, he'll chime in. Easy bike to work on, at least you can yank the motor out of the frame by yourself....
  3. Thanks, Drewps, yeah, I was thinking along that line, but needed a kick in the butt to get me moving in that direction. I have other bikes that require more immediate attention, but one afternoon I will sit down beside the mighty 400 and become one with the ignition....I'll let you know the results, eventually...add to the community knowledge....
  4. This issue has likely been already answered somewhere in here, but I couldn't find anything using several search terms...nonetheless, I apologize in advance... My '78 XS 400E starts easily on the kick-start (starter not working...winter project), idles fine at around 1300rpm, carburates smoothly during normal acceleration in all gears, except at around 5500 and above, and going up hills in top or 5th gear. Then it hesitates a bit, and won't give any more than about 6000rpm. Battery is fully charged, new gas, carbs have not been rebuilt, but were dismantled and blown out with carb cleaner and compressed air. No crap noted in float bowl when taken apart. No rip/pin holes in diaphragms. Carbs visually bench synced. Petcock screen clean, petcock rebuilt, new vacuum and fuel lines, as well as carb boots. Stumped.....
  5. The alternator cover is on the left side of the engine, as you sit on the bike. If it was full of oil, yikes, crank seal, I'd imagine. Ah, the joys of learning all about a new bike, the head-scratching, the oil stains on the shed floor, the cursing, the apologizing to #1.....
  6. I got my kit from Keyster.....easy job to refurbish the petcock, only about 7 parts to worry about....
  7. I just replaced my old balls (does that sound right?) with tapered bearings....bought them from the local Yamaha dealer, they supplied an aftermarket kit with top and bottom sets and both seals through a supplier called "All Balls. They slipped right in properly (with the right gentle tapping with a small drift), and the whole job took less than an hour...was finished by coffee time this Tuesday AM. Take your time thinking the install through before you put the new ones in, and it will go smoothly.....cheers
  8. Recheck the intake boots, as even small cracks in an older, dried out one can change the mixture....spray WD-40 around the intakes while it is idling...if the RPM cganges, you still have air leaks. The boots are available on ebay, or from Yamaha with more money, and change the intake gaskets as well. Good luck.
  9. You can get the boots on ebay: http://cgi.ebay.com/INTAKE-MANIFOLDS-1978-YAMAHA-XS650-78-XS-650-79-/380161301756?cmd=ViewItem&pt=Motorcycles_Parts_Accessories&hash=item5883611cfc Cheaper than buying from Yamaha, but you'll still need the intake gaskets...they are still available from Yamaha.
  10. Personally, I like the idea of painting the rims without removing the tire...no masking, quick and dirty change of appearance, you know that one day you'll find the time to do it right...yah, right.....
  11. Houghmade, Very nice clean-up, there, that bike looks nicer than new...I like the mufflers. Congrats on a sensitive "rizn-frm-thded"....
  12. Drewps, thanks for fixing my photo problem...I've never been able to post piccies, now I know the problem. The seat is basically a stock XS400E seat, reshaped stock foam, and a custom cover, so it still maintains the stock seat pan and mounting hardware. One of the guys in our local British Columbia Collector Motorcycle Club ()is an upholstery wizard, does the seats for some of the local Harley custom builders. I just told him kinda what I would like, and left it with him....pretty cool...
  13. "Say Runningdog, what are some of personal treatments for the xs? " Sorry I took so long to reply to this query....must have been working on the bike.... Over the winter, aside from doing the usual maintenance/repairs required to bring an older bike kicking and screaming into the 21st century, I got the tank and side covers painted (silver tank, black side covers), got the rather bulbous stock seat shaved and shaped into a soft bum-stop, installed clubmans, cropped the rear fender, installed a small round tail-light from a '65 CA200 (with home-made bracket), swapped the old fuse block for a new type, shortened the stock signal shafts, and dreamt about what to change next. I know that this post is really about leaving a xs 400 stock, but I've already done that a few times...time to change a bike that still has lots of very nice examples rolling around.
  14. Sometimes I think that Bikez is put together by non-bikers......the '78 XS400 has both rear discs (400E, mag wheels) and rear drums (4002E, spoke wheels). Photo on Bikez is of 400E, and you can see rear disc.
  15. Look closer...Bikez says tire size, not rim size. A 110/90 is about the biggest you'll get on the front (clearance), and maybe 120/90 on the stock rim on the rear...go for the 16" XS650 special rim on the rear, will make the bobber look right.
  16. For the tank dampers (and lots of other parts), try these folks.
  17. Any bike dealer can get you sprockets through their suppliers, likely Motovan. Wheels must be off a 2E.....
  18. Stock mounting system is a stud....looks like your's is bolted, which makes it pretty simple, don't have to worry as much about eye width, just add spacers as needed to fit snugly.
  19. My '78 XS400 has unloaded shock length at 12.5"...your frame looks the same as mine (except the rear downtube loop for supporting the rear pegs and exhaust appear to have been removed on your's). Like the rearsets, by the by.... Those shocks don't look immediately familiar, but someone else will surely recognize them. Almost any shock with the correct length and mounting eye width will fit (except for HD ones, right length, different eye width).
  20. Go to Canadian Tire, and get some Evaporust (Envirorust)....should be in the body supplies section....check out the British Columbia Collector Motorcycle Club forum: http://www.bcclassicmotorcycleclub.com/simplemachines/index.php?topic=425.0 a bit of a discussion on this stuff here.
  21. Don't be intimidated by wiring..at this stage, run through the entire bike and clean every connection you come to.....takes time, sure. Pay particular attention to grounding (black wires, generally, on a Yamaha). Do you have lights/signals/horn function? Good luck...at least, you'll know the bike by the time you go throuigh this exercise.
  22. I did it in BC....contact the Provincial Vehicle Licencing agency, even on-line, and search for a guide for registering vehicles with no papers...likely need to show that you did due diligence as far as talking to previous owner(s), document everything you do to get bike info, and you may need all info notarized...it'll all be explained in guide, if it exists. New Brunswick is private insurance, is it not? Good luck, it won't be done overnight....
  23. Detsta....at least your bike has tubular bars...you can replace the stock bars with after-market ones, with the bend/height/pull-back you like. I have a friend with the same bike, and she's about 5'4"...she has different bars, and loves the comfort on her ride.....visit your local bike shop.
  24. "Oversized tires made mine handle like a Harley Sportster." That's good to know...mine has oversize tires, and really needs persuasion to change direction...mercifully, they are almost worn out, so new (and correct) skins are in the offing.
  25. Normally, I try to do whichever bike I've rescued back to OEM, or dang close. However, I got the urge to do something a bit more personal, and settled on an XS400, as there are so many of them, and "fix-up" parts are plentiful. No other excuse for massaging an otherwise very capable scoot. Mind you, if the Canadian '78 XS400 had the same style as the Euro/Brit version, it may have been a different story. Drewpy, I love your bike.
