Bad Alternator on XS400SG?
Ok, will do. Thanks.
Had a weird electrical situation that left me stranded last fall and want to test the electrical system on my 1980 XS400SG. I got as far as checking the output(?) at the battery while the engine is running at or above 2,000 rpm. The Haynes book says it should be at least 14.5v but mine was only reading about 11.3v. Am I correct to assume that the alternator isn't putting out what it's supposed to? Should I do some further testing on the alternator? Battery was somewhat recently charged. (should I first charge up the battery then do the output test?) Thoughts?
- Lost key!
- Lost key!
Lost key!
Thanks for the offer Ttaskmaster but I think the airfare would kill me! I tried fiddling around with a screwdriver and pick and didn't have any luck. The other key I have won't even go in so I called a few places: Locksmith A wanted $75US to pick it and cut a new key. Locksmith B said they could do it for $25 - $40US. Then I called a Yamaha Dealer. $18.52. They cut a new key from the code I provide them and presto! (I hope.) Will go up there hopefully on Friday and see how they do. Will let you know it works out. Thanks for the suggestions!
- Lost key!
- Lost key!
Better headlight for 79 XS400?
Can anyone recommend a headlight upgrade for a 79 XS400? Mine sucks.
79 XS400 - Hard starting and poor idle.
Just wanted to let everyone know that I finally go the old cow running properly! Didn't really need to blow out any passages in the carbs although I did, after thoroughly stripping them, soak the carb bodies in carb cleaner, spray them down with brake-clean and then dry them off with compressed air. Put all the bits back in and after some trial and error with setting the float heights got it running better than it has ever before (for me anyway). Starts on the first kick (still need to replace the starter motor) and runs beautifully. Smooth, powerful and the mileage, upon first check, is above 50mpg. That's for a lot of stop and go city riding and some fiddling around with the idle speed. Thanks so much for everyone's help! Looking forward to putting many miles on this bike. My wife has even signed up for the Motorcycle Safety Foundation Course to get her license. Ciao.
Big fuel leak from rebuilt Carb
Well, hallelujah. Finally got the damm thing running properly. I lost count of how many times I took the carbs off, changed the float heights and put them back on. What finally worked for me is setting the height at exactly 1" (when upside down, on the bench)(distance from edge of carb body to uppermost edge of float. I tried them at 1.07" and it ran like crap. I tried it at 1.15" and it ran like crap. I tried it at 1.0" and it runs beautifully! I gave up trying to measure them by tilting the carb and blowing air through the fuel supply inlet because a. I would have to have made some kind of rig to hold them steady while I adjusted the float heights and b. it simply wasn't very repeatable. There didn't seem to be a point where the air (fuel) would abruptly stop. Instead it would gradually taper off so it was hard to tell at what point to take the measurement. I even tried a neat suggestion found elsewhere about running fuel into the carb (while on the bench) and then measuring the actual fuel level in the bowls by running a clear vinyl tube from the fuel drain at the bottom of the bowl up alongside the bowl so you can see exactly where the fuel level is. (Setting Float Heights) That sort of got messy because I had bad connections with my bench hoses. So in desperation I resorted to trial and error and getting it in 3 tries eventually. Ugh! Still pops a little at idle so I may try to tweak it a tiny bit, but man does it run a whole heck of a lot better now! It's like a different bike! Tons more power and response. Starts easily and idles much better. This has the BS34IIIs on it so I can't adjust the idle mixture. I think all I have to do now is synchronize the two carbs and I'll be on to other chores on the bike.
So do you think these specs would be good for my 1980 BS34 III carbs?
Awesome, thanks. Is this for the model II or model III BS34?
Service Manual for Mikuni BS34 II and/or III?
I've been struggling to clean and rebuild the carbs from my 79 XS400SG and aren't too impressed with the Haynes Manual. Does anyone know if there's a good manual for these carburetors out there? I found something at Lambretta Works's website http://www.lambretta.net/shop/shopexd.asp?id=3996 but it doesn't include those models. I'm new to carburetors and am eager to learn about how these things work and exactly how to work on them.
- Big fuel leak from rebuilt Carb
Now I'm really confused! 1. I thought the floats shut the fuel flow off when they were bottomed out as in the pictures (or raised when in their proper orientation when mounted on the bike). When the floats rise, they push the needle valve assembly up so that the rubber cone seats and closes off fuel flow, right? 2. I'll reset float height to 1.1" while holding the float at it's maximum height (while upside down on the bench). 3. I was told that they're BS34 IIIs from a 1980 and later US vintage because the idle mixture screw is capped off as show in this picture: - Big fuel leak from rebuilt Carb
grusvag
Joined
Last visited
