URBANTIGER
  1. i cant remember when i restored my own rd250 but think my own shaft when oil pump was off had a good inch of lateral play in it..
  2. he says that the drive that comes out of side of engine once pump is removed can be pushed in an out...he also says that the pump seems to fit onto the engine and drve shaft ok but has now way of telling if the pump is turning once fitted..think it is the same pump as my own bike..has one visible wheel/cog inside pump once its removed from engine
  3. he says that the drive that comes out of side of engine once pump is removed can be pushed in an out...he also says that the pump seems to fit onto the engine and drve shaft ok but has now way of telling if the pump is turning once fitted..think it is the same pump as my own bike..has one visible wheel/cog inside pump once its removed from engine
  4. he says that the drive that comes out of side of engine once pump is removed can be pushed in an out...he also says that the pump seems to fit onto the engine and drve shaft ok but has now way of telling if the pump is turning once fitted..think it is the same pump as my own bike..has one visible wheel/cog inside pump once its removed from engine
  5. hi mate just off the phone who hasnt got a computer to post this.. he has like me an rd250e..it was running fine when he took the engine out to strip and rebuild it.. it was off the road past 3 monthes and when he rebuilt it he couldnt get the oil pump pipes primed,,the main oil feed pipe bleeds ok but no oil flows to the carbs no matter what he has tried.. he got the bike running ok using premix at 33/1 (is this a correct ratio?) and tried priming the pump by opening the oil pump fully while bike was idling..nothing.. when he revs the bike he notices the end of the oil pump shaft irregulary moves in an out..is this normal?..he has taken the pump off 3 times and refitted it and the gear inside the pupm he says turns ok..he kept the pump spaked in petrol to clean it for the 3 monthes it was off the road.. any help would be very much appreciated..
  6. hi mate just off the phone who hasnt got a computer to post this.. he has like me an rd250e..it was running fine when he took the engine out to strip and rebuild it.. it was off the road past 3 monthes and when he rebuilt it he couldnt get the oil pump pipes primed,,the main oil feed pipe bleeds ok but no oil flows to the carbs no matter what he has tried.. he got the bike running ok using premix at 33/1 (is this a correct ratio?) and tried priming the pump by opening the oil pump fully while bike was idling..nothing.. when he revs the bike he notices the end of the oil pump shaft irregulary moves in an out..is this normal?..he has taken the pump off 3 times and refitted it and the gear inside the pupm he says turns ok..he kept the pump spaked in petrol to clean it for the 3 monthes it was off the road.. any help would be very much appreciated..
  7. hi no i havent taken to any shows... im a northern irish guy now living in skipton...the dt and lc is at my mothers in ireland...just got the rd250e and a gsxr here in skipton.. next time im over in ireland gonna bring the dt back here with me.. cheers sean
  8. HI GUYS.. SOME PICS OF MY RESTORED RD250E..DT250MX AND RD250LC...WANTING A DT400 B TO DO NEXT..ANY HELP?
  9. hi tomy... dont have no money now :-) as for time spent a few hours every other evening at them..or sometimes till the early hours.. did all the work myself apart from blasting and painting an plating..the dt was the first time i ever built a set of wheels cheers sean
  10. HI GUYS.. BEFORE COMPLETING MY DT250MX LAST YEAR I STARTED ON THE FULL RESTORATION OF MY 79 RD250E...FINALLY GOT IT FINSHED YESTERDAY.. NEXT PROJECT..DT400B/C..IF I CAN FIND ONE HERE IS SOME PICS OF MY 1980 DT250MX I FINISHED RESTORING ALSO.. THIS WAS HARDER TO FIND PARTS FOR THAN THE RD250 IVE JUST DONE.. DATES ON PICTURES IS ALL WRONG BY THE WAY..
  11. HI GUYS.. BEFORE COMPLETING MY DT250MX LAST YEAR I STARTED ON THE FULL RESTORATION OF MY 79 RD250E...FINALLY GOT IT FINSHED YESTERDAY.. NEXT PROJECT..DT400B/C..IF I CAN FIND ONE HERE IS SOME PICS OF MY 1980 DT250MX I FINISHED RESTORING ALSO.. THIS WAS HARDER TO FIND PARTS FOR THAN THE RD250 IVE JUST DONE.. DATES ON PICTURES IS ALL WRONG BY THE WAY..
  12. HI GUYS.. BEFORE COMPLETING MY DT250MX LAST YEAR I STARTED ON THE FULL RESTORATION OF MY 79 RD250E...FINALLY GOT IT FINSHED YESTERDAY.. NEXT PROJECT..DT400B/C..IF I CAN FIND ONE HERE IS SOME PICS OF MY 1980 DT250MX I FINISHED RESTORING ALSO.. THIS WAS HARDER TO FIND PARTS FOR THAN THE RD250 IVE JUST DONE.. DATES ON PICTURES IS ALL WRONG BY THE WAY..
  13. HI GUYS.. BEFORE COMPLETING MY DT250MX LAST YEAR I STARTED ON THE FULL RESTORATION OF MY 79 RD250E...FINALLY GOT IT FINSHED YESTERDAY.. NEXT PROJECT..DT400B/C..IF I CAN FIND ONE HERE IS SOME PICS OF MY 1980 DT250MX I FINISHED RESTORING ALSO.. THIS WAS HARDER TO FIND PARTS FOR THAN THE RD250 IVE JUST DONE.. DATES ON PICTURES IS ALL WRONG BY THE WAY..
  14. hi i have bought an early 1983 reg rd250lc 4L1 and the pump oil cover cover on right hand side is different than that on my 81 reg 250lc..was there a difference in the covers over the years.. here is a pic of my 83 bike... thanks sean have a look at my other bikes i have an am restoring
  15. HI ALL.. AT PRESENT IM RESTORING A 79 UK MODEL RD250E...HERE IS A PIC OF HOW IVE GOT SO FAR...REBUILT AND PAINTED ENGINE..POWDER COATED FRAME ETC..LOTS OF NEW GENUINE YAMAHA PARTS AND REPLATED NUTS AND BOLTS..RESPRAYED BODYWORK..NEW FRONT MUDGUARD..TYRES..ETC ETC ETC..AM LOOKING A NEW OLD STOCK REAR MUDGUARD OR A MINT SECOND HAND ONE..ALSO MINT DOWN PIPES.. THIS IS MY 81 DT250MX UK MODEL WHICH IVE ALMOST FINSIHED RESTORING..ALSO HAVE A TY250 MONO..HONDA CB1000 AND CB900F.. HERE IS A RANGE OF TEE SHIRTS IM SELLING WITH THE SPEEDBLOCK LOGO FROM THE 250 400 E RD SERIES..ALSO WILL BE DOING THE 250/400C+DX GRAPHIC. SHIRTS WILL BE COLOUR OF THE TANK.ALSO A RANGE OF SHIRTS WITH IMAGE OF THE BIKE ON THEM.. TOP QUALITY FRUIT OF THE LOOM SHIRTS..AT PRESENT AVAILABLE MED LARG AND X LARG.. PRICED AT 11.99 PLUS 1.25 POSTAGE WITHIN THE UK. PLEASE EMAIL [email protected] FOR MORE PICS OR ANY QUESTIONS..I HAVE A BUY IT NOW ON EBAY
