steve m
  1. There are no known problems with the FZS/Fazer gearbox (except damage by heavey footedness ) if it`s a new bike ,,, take it back to the shop.
  2. steve m replied to troyboy's topic in Naked
    Try it,, see what you think ? if it`s not for you then put it back " as was" you only need to disconect the servo cables from the exup valve (no need to remove them) wire the valve open and se how it goes........... Ps, make sure you make a note as to which cable goes on which side of the pully, better still take a picture ..
  3. steve m replied to Jimmi's topic in Naked
    Got BT021s on the Fazer thou and the wife has them one her Fazer600, they are a good tyres, but the fronts have worn faster than the rears, looks like it could be two fronts to one rear !! Going to try the new Dunlop Road Smartsnext, they seem to have a good write up.
  4. CPC
    steve m replied to JimR's topic in The Bar
    """I've already got a NVQ in transport" A shiver ran down my spine at that little gem""" sanctimonious t**t !! There is no requirement for a course to include a test or pass/fail element. So, you have obviously done the CPC, so I wonder what your thought are on the syllabus ?? """I have every qualification going""" Do you really """"If you seriously think your knowing the difference between a road wheel and a steering wheel makes you a good driver you should enrol now. """ Do you know me ?? or what experance i have ? before passing your judgement on other people, get to know them first !!
  5. CPC
    """""""PS I think you'll find dust cart drivers may be exempt """"""" CPC booklet Periodic training is designed to complement the individual drivers work and be relevant to their everyday job. Courses may include defensive driving techniques, first aid, health & safety, driver’s hour’s regulations and tachographs. Courses will also enable drivers to keep up to date with changing regulations. The syllabus broadly covers: • Safe and fuel efficient driving • Legal requirements • Health and Safety, service and logistics. There is no requirement for a course to include a test or pass/fail element. Allready done the first syllabus 7 1/2 hours of total boredum !! I allready hold an NVQ in transport, but I still have to do the CPC !
  6. steve m replied to JohnnieM's topic in Yamaha Workshop
    5 spoke are correct for the year. Sorry, Not sure what other wheels will fit.
  7. steve m replied to awxjr's topic in Yamabyss
    Works for me every time
  8. Sounds like a starter motor problem, the clicking you hear will be the relay working, but still worth checking it out first.
  9. Engine and frame No starting from 12R -000101 are the DOHC engines, your model should be for 1982 the XS400J. As drewpy says """the 12r and 12e for your purposes, will be the same""" The engine specs are the same as the XS400RJ (12E) but the carbs are differant ( Mikuni BS43/12R-00 on the J and BS34/16m-00 on the RJ) as are the main jets ( LH jet 125 RH jet 115 on the J and LH 127 RH 117.5 on the RJ )and also the rear sprokets (35 tooth on the J and 38 on the RJ) XS400RJ with DOHC engine.
  10. steve m replied to Blades_2's topic in The Bar
    Wot you all woried about ?????????????????????? Gordon will sort it all out, no problem !!!!! 2 pence a litre on petrol and chuck in few more speed camaras,,,,,, job sorted
  11. steve m replied to Blades_2's topic in The Bar
    """These brave men should be allowed to stay in this country - and it pisses me off that so many illegal immigrants are allowed to stay without so much as a bat of an eyelid, yet the Gurkhas arent allowed? """ Yep, got to agree, let them in,,,, then send a troop of them off to the Euro Ports to help befend our Borders,, that should help keep some of the illegals out
  12. More than likley that the valve needs a strip,clean and lube, this is something that should be done every service really, ( I do mine every couple of thou miles ) unfourtnatly, Mr Yamaha never thought to add it to the servicing schedule, so more often than not it gets missed and the first you know of it is when the dreaded ExUp fault appears......... Yes it is a job you can do yourself but,,, before you start pop on to this SITE and have a look round, you should find all the info you need to do the job and any advice you need,just ask,,, another but !! first of all introduce your self !!
  13. steve m replied to Mayharg's topic in The Bar
    Try HERE
  14. Should be a 60/55 watt bulb if it looks like THIS ( H4 bulb ) then you should be able to pick one up at any auto shop.
  15. steve m replied to squiz's topic in Yamaha Workshop
    Sticker should be on the bike under the seat ? 1999 Fazer model code 5DM4 Color Code SM1,,,,,, Silver Metalic 1 ..........
