phermes1
  1. Plenty of gas - but it's a good question. The lights work. I don't have a horn. The kill switch functions - when it's off, the engine doesn't turn over at all. It'll crank just fine; it just won't spark, much less start.
  2. Hey all, I just joined this forum and was hoping for a little help. My Beartracker - yes, I have a quad, not a bike, I'm hoping someone will still help - was running fine and just stalled on me. It will turn over but will not start, and I'm not getting a spark from the plug. I tested the connections going into the ignition coil and they don't seem to be getting any current. The fuses test out OK, and the relay appears to be working, for as much as I'm able to test it. I've inspected the wiring and connections and it all looks solid. Has anyone had this happen to their bike/quad and what was the cause? I'm strongly suspecting the CDI. It stopped running out of nowhere, and hasn't even thought about starting since. If it was a bad connection, I wouldn't have expected it to break down so quickly and so absolutely. Any help is appreciate. Thanks, Paul
