jaime
  1. okay guys thanks alot all the info was alot of help ..everything checks out okay as far as the ignition coils are concerned but the #2 cyl. sill feels cold to the touch .. i did notice one thing and thats when i covered the opening to the carb. and made it suck up more fuel the cyl. came alive so now im confused i know that they cant be clogged because i took the apart and cleaned them well so why is this cyl. the only one that's not firing it is getting fuel ...I'M now thinking maybe it needs a carb. sync....im going to check on that next ....i will let you guys know what happens .......or do you have any other ideas or input please let me know thanks ..
  2. Hello.... was the bike sitting for a while with out being started if so your problem may be a cloged idle circuit .. the symptoms that you describe is usualy caused by a clogged idle circuit to correct this the carbs need to be completely cleaned and taken apart and checked. every little orphis must be clean and free of obstruction some holes are smaller than the size of a small needle so make sure all is clear....(UNLESS YOU KNOW WHAT YOUR DOING YOU COULD BE OPENING A CAN OF WORMS)..if you never cleaned carbs before or dont know much about them take them to a local shop there is alot more to cleaning carbs than just spraying them with carb cleaner .....!!!
  3. hello all i have a 1994 fzr 1000 and im having trouble with the 2nd cyl not firing i have changed tha plug twice and still no luck i even went as far as turning the ignition over while the plug is connected to the cap and out of the bike grounded when i do that i could see a faint spark but when i put the plug back in the bike i still get no spark because when i touch the down pipe comming from that cyl. its cold when the other are good and hot ....please help with some ideas or if any body know what the resitance values are so that i could test the coils I my self am running out of ideas any feed back is greatly heplp full .......thanks in advance (keep on riding)!!
