Indicators Not Working
Hi
I am after a bit of help, the indicators on my 82 xt400 (grey import) will not work when the engine is running. They did work before I fitted a new battery, now they will only work with the ignition on and engine not running. Any ideas?
Thanks
Mark :unsure:
check around the battery to see if you loosened a connection, or ground ,. only a guess but motor running is drawing off power??
That's a damn good guess mate.
If you have a multi meter check the battery voltage without the engine running, you should get a reading of about 11.2 to 11.8 volts, start the engine and check again, you should now get a reading of up to 13.8 volts.
Indicators now working. Thankyou Jeepurz & Bovril for the advice. I went round to the garage multimeter at the ready. Tried the indicators with engine not running, worked fine. I then started engine indicators failed to work. I then stopped engine put indicator on then started engine again this produced the desired result and indicators are now working perfectly. I don't know if this was just a fluke but all is well now.
Thanks for the help.
Mark
