May 18, 200817 yr Hi I am after a bit of help, the indicators on my 82 xt400 (grey import) will not work when the engine is running. They did work before I fitted a new battery, now they will only work with the ignition on and engine not running. Any ideas? Thanks Mark
May 18, 200817 yr check around the battery to see if you loosened a connection, or ground ,. only a guess but motor running is drawing off power??
May 18, 200817 yr check around the battery to see if you loosened a connection, or ground ,. only a guess but motor running is drawing off power?? That's a damn good guess mate. If you have a multi meter check the battery voltage without the engine running, you should get a reading of about 11.2 to 11.8 volts, start the engine and check again, you should now get a reading of up to 13.8 volts.
May 26, 200817 yr Author Indicators now working. Thankyou Jeepurz & Bovril for the advice. I went round to the garage multimeter at the ready. Tried the indicators with engine not running, worked fine. I then started engine indicators failed to work. I then stopped engine put indicator on then started engine again this produced the desired result and indicators are now working perfectly. I don't know if this was just a fluke but all is well now. Thanks for the help. Mark
