May 11, 200818 yr Hiya Folks New to this forum but like what Ive read and seen so far. heading off to North west 200 on weds and doing some final chewcks thsi morning find I have a problem with my indicators. When I swelect right hand ind they work but no left hand. Have checked and changed fuse and all bulbs, I aslo notice that I have no hazards eother. \any of yuo guys suffered similar or have any other ideas. Cheers Stevie G
May 11, 200818 yr Moderator Try taking the switchgear off and giving it a good clean - that might solve it. If you have checked all the connections and they are ok then i have no idea - other than your switchgear might be knackered.
May 11, 200818 yr Hiya Folks New to this forum but like what Ive read and seen so far. heading off to North west 200 on weds and doing some final chewcks thsi morning find I have a problem with my indicators. When I swelect right hand ind they work but no left hand. Have checked and changed fuse and all bulbs, I aslo notice that I have no hazards eother. \any of yuo guys suffered similar or have any other ideas. Cheers Stevie G Think you will have to change the indicator relay. The contacts on one side are not working.
May 11, 200818 yr Author Try taking the switchgear off and giving it a good clean - that might solve it. If you have checked all the connections and they are ok then i have no idea - other than your switchgear might be knackered. Cheers will try this and let you know
May 11, 200818 yr Author Think you will have to change the indicator relay. The contacts on one side are not working. many thanks Yoda have tried cleaning switch gear so this will be next step. Will let yopu know how it pans out
