Hi
Just a post hoping that one of you guys (or girls) can give me any tips -
I have to dismantle my friends 600 Divvy to replace a bearing - I think it is the driveshaft bearing - but he is going to check with the garage that did the service) - Are there any tips or useful pieces of advice on doing the job? The Haynes manual is a bit rubbish - not one decent 'explosion' diagram on the engine!
Wish me luck.......
:D
..........................OK update to the Divvy problem.
Decided it was easier to fit new engine - so duly picked one up and started to take the old one out........nearly there only the rear engine mount bolt to remove.........4 hours later and it still wont budge - I've tried every tool in my arsenal, mullered both ends, and I can't get it to do anything.
Any of you guys got any ideas coz I'm clean out of them at the moment!
:angry:
Try scewing it in first and then out. Also heat the casing that the bolt goes into while turning the bolt. Failing all drill it out, carefully.
:angry:
Thanks, done all that but the bolt is too long and only got about 1" in. Any other ideas?
