Dragstar Emblem Removal
Hi, I want to remove the dragstar emblem from the side of my fuel tank and side covers. Has anyone got any tips on the best way to do it without marking the paint?
I did it by using a piece of wood like a lollipop stick, and gently inserting it between the emblem and the tank. It worked very well for the side covers too. If you do it just right you can get the emblems off without damaging them as well. They are just held on with glue which should come off in one lump
Thanks, I'll give it a go.
Try a bit of WD40 too - i used it to take off the sticky mess (oooooerrrr!) left by the foam seal around the clocks when the tank went for a respray - worked a treat!
