April 30, 200818 yr Hi folks i have a couple of questions: I have heard about getting the 1000 exup dynojetted. Is it recommended and how much does it cost? Jack up kits. Are they just for show or do they increase handling? Hope to hear from you
April 30, 200818 yr Moderator Hi folks i have a couple of questions: I have heard about getting the 1000 exup dynojetted. Is it recommended and how much does it cost? Jack up kits. Are they just for show or do they increase handling? Hope to hear from you Jack up kits, would be surprised if they improved handling because the will change the geometry, They will however make it further from the seat to the road so you need to be tall enough for this to be not a problem.
May 3, 200818 yr Moderator Hi folks i have a couple of questions: I have heard about getting the 1000 exup dynojetted. Is it recommended and how much does it cost? Jack up kits. Are they just for show or do they increase handling? Hope to hear from you forget the dyno jetting and just get the carbs balanced and maybe get a new set of emulsion tubes if your comsumption is in the 30's. I know a good man that does some lovely polished stainless steel dogbones(jack up's ) check your PM's m8. hth.
