Can I ignore XJ600S Diversion oil cooler?
Hi!
I have 1993 Xj600S Diversion with a faulty engine. Tomorrow I`m gonna get another engine, from a newer model(1999). These newer models have an oil cooler, but everything else seems to be the same. Can I just ignore it and connest oil cooler hoses together? Earlier models could easily do without it, so would it be a problem in this case?
If any answers, thanks a lot!
Hi!
Why can't you just fit an oil cooler?
Haven`t got one
Haven`t got one
See your problem, and there might not be any points to attach a cooler to the frame like on the newer bike. But the designers have deemed that this engine needs one and if it were me i'd try to fit one.
Haven`t got one
Is the oil capacity the same on both engines? If the newer engine holds less oil that is the reason for the cooler - I'd guess. :blink:
Hi!
The Air Cooled Motors are known to run a little hot when in traffic and driving slow and the oil coolers help heep the temps down Its up to you.
