Hi guys,lost my keys recently for my 1994 yzf 750.it was my only set and my steering lock is also on!!does anyone know where i can get a replacement?also i thought of breaking the seat lock off and having a key made to the number on it,will this fit the ignition? i know there is a seperate key for the fuel tank but cant remember if the ignition and the seat lock are the same key,thanks in advance
There should be a code on the side of the ignition switch (label on the switch housing). Take that code to any good locksmith. If you don't have any overseas I am sure I could get one made for you here in the states. You should be able to remove enough plastic to get to the lock assy without the key.
Sean
