April 22, 200817 yr can you use a fork bracket as a frame bracket as long as the down tube is the correct size? 34mm down tubes.... 34mm bracket that should go on the fork tube? can you use it for the frame bracket?
April 22, 200817 yr Moderator can you use a fork bracket as a frame bracket as long as the down tube is the correct size? 34mm down tubes.... 34mm bracket that should go on the fork tube? can you use it for the frame bracket? eh?
April 23, 200817 yr Author http://www.mikesxs.net/mikesxs-suspension....category_id=6.3 http://www.mikesxs.net/mikesxs-suspension....category_id=6.3 two brackets and one damper. can so my question again, can you use fork bracket as a frame bracket for the damper to mount to?
April 23, 200817 yr Moderator http://www.mikesxs.net/mikesxs-suspension....category_id=6.3 http://www.mikesxs.net/mikesxs-suspension....category_id=6.3 two brackets and one damper. can so my question again, can you use fork bracket as a frame bracket for the damper to mount to? Its possible, but adapting the bracket would be troublesome. usually its a shaped homemade bracket welded to frame is easiest way
