can you use a fork bracket as a frame bracket as long as the down tube is the correct size? 34mm down tubes....
34mm bracket that should go on the fork tube?
can you use it for the frame bracket?
eh? :blink:
http://www.mikesxs.net/mikesxs-suspension....category_id=6.3
two brackets and one damper. can so my question again, can you use fork bracket as a frame bracket for the damper to mount to?
Its possible, but adapting the bracket would be troublesome. usually its a shaped homemade bracket welded to frame is easiest way
