My diverson has water in the oil,the crankcase to airbox preduses water.I have flushed her twice but did no good .Since leaving the breather pipe off I ran for 30 miles and everything seems clear.
The pipe is now back on should the problem come back ?
The bike was stood for 3 years but started once a week for 20 mins at a time.This may've contributed to the emulsification do you think ?
An after mkt exhaust 4 into 1 [ motad,nexus] has been fitted what size carb jets should i fit if i need to ?
HELP
HELP
you need to RIDE THE BIKE! this is the best way to keep the engine in good condition.
the engine isn't getting hot enough as it need to be under load.
