Checking Oil
Newbie here.
Still riding my 76' XS360 street bike. Can't get it faster than 55mph but i still love it.
Can you tell me what is the proper way of checking the oil?
Should the bike be on the center-stand? You have to unscrew the oil stick. Should I unscrew, wipe the stick clean, rescrew back in, unscrew again to check the oil ??...
I just need to be sure I'm doing this right. I'm afraid I'm a little low on oil. Oh and should I call a local shop for what type oil to use or can any of you here tell me?
Thanks.
Sophic
Newbie here.
Thanks.
Sophic
should go faster than 55 I get the ton out of my 400, 250's will do 80mph
bike on centre stand, level ground, unscrew the dippy, wipe it, then rest on top without further screwing ( sounds a bit rude this post!) pull out and check level.
I recommend using 20w 50 millers classic sport oil semi synth or equivelent oil in states
http://www.millersoils.net/1_Millers_frame_BIKE.htm
