Posted April 15, 200817 yr This Motorcycle has only 1200 miles and is in excellent condition. I had remove the gas tank and clean it out good and now it like brand new no rust inside. I also had put in new battery and put new gas in it and change oil and oil filter. I also had removed the carburator and clean it . Put everyting back togetther and try to start but it wont start. anyhelp what should I do?
April 15, 200817 yr I would start with the basics, like has it got a spark, also carbs may need a good clean. The starter jet in the float bowl is tiny and gets blocked real easy, bad part is you cant remove that jet to clean you have to do it in situ.
April 15, 200817 yr This Motorcycle has only 1200 miles and is in excellent condition. I had remove the gas tank and clean it out good and now it like brand new no rust inside. I also had put in new battery and put new gas in it and change oil and oil filter. I also had removed the carburator and clean it . Put everyting back togetther and try to start but it wont start. anyhelp what should I do? You might want to put some fuel in it.
April 23, 200817 yr This Motorcycle has only 1200 miles and is in excellent condition. I had remove the gas tank and clean it out good and now it like brand new no rust inside. I also had put in new battery and put new gas in it and change oil and oil filter. I also had removed the carburator and clean it . Put everyting back togetther and try to start but it wont start. anyhelp what should I do? I had a similar problem: my '86 was really cold blooded and then one day it just died on me for apparently no reason. For me, the problem was carb synchronization. Now it runs better than ever. I tried all that you did, with no result, so I found a dealership that would work on older bikes. Hope this helps.
