MOT failure
Hi, Bought a 1997 P.reg thundercat a fortnight ago for a good price, replaced the front pipes and front tyre and put it in for a MOT
Sadly it failed on stiff rear suspension, needs to have 4 inches of movement?? Also a leaky front caliper which i think just needs a seal kit
The thing that is boiling my blood is the stiff suspension, is this a common thundercat fault or do they just seize up
I think the bike has stood for a yr or 2, apart from these problems I'm very happy with the CAT
Some advice would be most helpful
Cheers
Help me please, with a cherry on top :mellow:
Cheers
Most shocks are adjustable isn't yours ? Failing that take it for a blast around sheffield, with all the pot holes here it should soon loosen it. ;)
hi , sounds to me your suspension linkage has seized, the bearings are all dry and have become solid, this is fairly common , you need to strip the shock linkages out clean them and grease them up and re fit, the shocks also loose their rebound damping due to loss of oil.its possible the the bearings may need replacing if in bad condition.....
Hi all, got it sorted. It was the linkage bearings, the one with the 2 bearings in with the long bush.
Im finally on the road
Thx for the advice all
Cheers
