My wifes xs400se only just holds its own charging with the headlamp on (ok with lights off). Is there anyway to upgrade the charging system because I'd like to put a decent halogen light unit on it, original is crap!!
Chris
Chris
It shouldn't do!! make sure the battery is fully charged and functional as this is required to charge up the battery (sounds daft, but the stator is excited by magnatism via the field coil and needs a good 12v)
you should be reading 14.5 volts @ 3k revs across the battery
