Posted April 11, 200817 yr hi all!, My name is Jesse, Im 23 years old and live in Seattle, Washington USA. I have a big project under way its a 1976 yamaha XS360C that im building into a custom cafe racer. It has: Raask adjustable clubman bars that i have cut and narrowed to make fit better pod filters custom exhaust with black graphite heat wrap replacement headlight headlight brackets custom steel cafe seat w/ custom upholstry maxxis tires drilled ft. rotor home made rear sets (soon to be replaced with ones im making at work) 17T ft. sprocket for more top end. & so much more.... check it out @ www.caferacermotorcycle.com I'm now looking into making this low milage engine work a little harder, i see that Newtronics makes a electronic ignition for it and raask makes rearsets but thats all the "performance"/aftermarket parts i can find. dose anyone know of anything else available or have any possable leads to companys that can mfg. parts for me. ~Jesse
April 12, 200817 yr Moderator try new cam http://www.megacyclecams.com/catalog/page57.pdf dial in your carb settings on a rolling road cheapest way i know the get better performance is to lose weight, so go on a diet!!!! .... welcome to the forum!
April 14, 200817 yr Author try new cam http://www.megacyclecams.com/catalog/page57.pdf dial in your carb settings on a rolling road cheapest way i know the get better performance is to lose weight, so go on a diet!!!! .... welcome to the forum! thanks drewpy! i have been searching for a cam. so are you saying use the XS400 cam? is it interchangable? ~Jesse
April 14, 200817 yr Author I ordered a pair of mikuni VM34 carbs this weekend, now i plan on finding out from drewpy if the megacycle xs400 cam is interchangable also im looking into accel super coil ignition system and a dyna points ignition booster. after i ghet the parts im gonna port & polish the head and run a thinner head gasket to up compression... thats gonna be the extent of engine performance mods. ~Jesse
April 14, 200817 yr Author oh yeah, im runnin crazy home made exhaust and pod filters thats it for engine mods and i put down 23HP 19ft. lbs of torque. on the dyno this weekend. (and thats with running it fairly lean) im shooting for 30-35HP with the engine mods. ~Jesse
April 16, 200817 yr Moderator thanks for the ideas folks ! hope to pick my 360 up this weekend !! about bloody time!!
April 17, 200817 yr Author I posted a "WTB" add on craigslist and found many people with xs400's that will sell me complete running titled bikes for $200-$500! i'm going to pick up a xs400 engine with cdi for $40! also if you check craigslist seattle there is a SR500 running and titled for $750! i want it!!!! I'm thinking about putting a stock XS400 cam in my xs360... anyone know if this will work??? ~Jesse
October 21, 200816 yr The XS400 cam on the site referenced was for 79 and up. Was that a typo or will the cam work on earlier bikes?
October 21, 200816 yr Moderator I posted a "WTB" add on craigslist and found many people with xs400's that will sell me complete running titled bikes for $200-$500! i'm going to pick up a xs400 engine with cdi for $40! also if you check craigslist seattle there is a SR500 running and titled for $750! i want it!!!! I'm thinking about putting a stock XS400 cam in my xs360... anyone know if this will work??? ~Jesse yes its got the same part number. only the mild cams offered to german markets are different.
