XS360 in the US
DeBortole
This post is 5732 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
hi all!,
My name is Jesse, Im 23 years old and live in Seattle, Washington USA. I have a big project under way its a 1976 yamaha XS360C that im building into a custom cafe racer.
It has:
Raask adjustable clubman bars that i have cut and narrowed to make fit better
pod filters
custom exhaust with black graphite heat wrap
replacement headlight
headlight brackets
custom steel cafe seat w/ custom upholstry
maxxis tires
drilled ft. rotor
home made rear sets (soon to be replaced with ones im making at work)
17T ft. sprocket for more top end.
& so much more....
check it out @ www.caferacermotorcycle.com
I'm now looking into making this low milage engine work a little harder, i see that Newtronics makes a electronic ignition for it and raask makes rearsets but thats all the "performance"/aftermarket parts i can find. dose anyone know of anything else available or have any possable leads to companys that can mfg. parts for me.
~Jesse
Link to comment
Share on other sites
try new cam
http://www.megacyclecams.com/catalog/page57.pdf
dial in your carb settings on a rolling road
cheapest way i know the get better performance is to lose weight, so go on a diet!!!! :lol:
.... welcome to the forum!
Link to comment
greetings and welcome DeBortole !
i like it , i like it a lot :blink:
Link to comment
try new cam
thanks drewpy! i have been searching for a cam. so are you saying use the XS400 cam? is it interchangable?
~Jesse
Link to comment
I ordered a pair of mikuni VM34 carbs this weekend, now i plan on finding out from drewpy if the megacycle xs400 cam is interchangable also im looking into accel super coil ignition system and a dyna points ignition booster.
after i ghet the parts im gonna port & polish the head and run a thinner head gasket to up compression... thats gonna be the extent of engine performance mods.
~Jesse
Link to comment
oh yeah, im runnin crazy home made exhaust and pod filters thats it for engine mods and i put down 23HP 19ft. lbs of torque. on the dyno this weekend. (and thats with running it fairly lean) im shooting for 30-35HP with the engine mods.
~Jesse
Link to comment
thanks for the ideas folks !
hope to pick my 360 up this weekend !!
Link to comment
about bloody time!! :)
Link to comment
I posted a "WTB" add on craigslist and found many people with xs400's that will sell me complete running titled bikes for $200-$500! i'm going to pick up a xs400 engine with cdi for $40!
also if you check craigslist seattle there is a SR500 running and titled for $750! i want it!!!!
I'm thinking about putting a stock XS400 cam in my xs360... anyone know if this will work???
~Jesse
Link to comment
  • 6 months later...
~Jesse
yes its got the same part number.
only the mild cams offered to german markets are different.
Link to comment
  • Recently Browsing
