Hi
Just collected my 2004 R6 and have a probably stupid question relating to bulbs - hoping for some advise.
What bulbs should be on when?
There appear to be three bulbs per side. The tiny little "running" light, looks like a side light. This is lit on both sides when the bike is fired up
Then there are two bigger bulbs. When i have the bike started i have one bulb lit on one side but not the parallel :unsure: . Should it be?
Then when i put on full beam only one bulb on the other side lights up same when i flash passing lights. Surely this should be both sides lit?
Can anyone please explain what i should have when?
Cheers
2 side lights, 2 main beams plus high beam and when indicating the beams should be on both sides not only 1 side.
Good luck mate
