April 3, 200817 yr My bike XJ600N has been stood over the winter and now seems to have developed a problem when revving down, it starts popping. My first thought is it sucking air in through the carbs. but cannot see where. Everything working well revs no probs drives spot on but just pops when I close the throttle. Any help would be appreciated.
April 8, 200817 yr I also own an xj600n and the previous owner had the same problem, he found it to be a small hole in the down pipe of the exhaust and ended up replacing the full thing with a motard system which has made the bike sound awesome and improved the looks tremendously
April 8, 200817 yr Author I also own an xj600n and the previous owner had the same problem, he found it to be a small hole in the down pipe of the exhaust and ended up replacing the full thing with a motard system which has made the bike sound awesome and improved the looks tremendouslyThnkyou I will give it a try saves me from stripping the carbs down. Makes sense I know my exhuast is blowing slightly tippicle divvies.
April 9, 200817 yr Where did ya get yr motad from Rob? i'm on the lookout for one but want to get the best price, can't really find any under 300quid
April 10, 200817 yr It was the previous owner who got the motad system. he paid £600 for the full system but im unsure where he got it from sorry. Quick note: just been on intobikes.co.uk and they do the full system for £385.40 inc VAT.
April 12, 200817 yr In my opinion just changing the exhaust system might not help, but will cost a lot. Poppig is usually happens when air-fuel mixture is not set correctly, or the ignition time is bad. Loud popping in the exhaust pipe means that the fuel is not burned in the engine, and it explodes in the pipe. 1.: Check all sparkplugs. (gap, oxidation, etc...) 2.: Clean the carbs. And set them correctly. 3.: Set ignition 4.: Check the exhaust or change it, if you want to... If your motorcycle was stored for the winter with fuel in the tank you have a 0. option, drain all the old fuel, and fill it up with new fuel. Fuel falls apart with time.
April 15, 200817 yr Author Took the exhaust system off fitted new gaskets and sealed around everything with exhaust paste. Cured the problem and so much quieter.
