DT 125 HELP!!
Hi, i got a dt 125 a few weeks ago and everything was working fine and then the right side indicators stoped working.. i got a new switch gear and there is still no life in the right side. The left side is fine but when i indicate right then try to indicate left it wont work. i have to pump the indicator switch in a few times then flick it left. i know it sounds wierd but any ideas??
thanks
scott
Hi,
i presume that you have checked the bulbs on the right hand side of your bike to make sure that they are all ok and the fuses, the next thing to check would be the wiring on the right hand side,check the earth's and see if you have power going from the right hand side of the switch to the indicators B)
Hi,
im not sure where the fuses are mate. can you help me?
dont bother looking at fuses if left side works cause they both work off one fuse for indicater system, most likely blown bulbs or wiring fault to rh side , poss switch fault also, may not be sending live feed to system. the live wires on rh side are green and they are brown on left side. the black wires are the earth wires, let me know what you find. you need 12 v going to indicater when switched. and also 12v returning back to earth.
