Posted March 30, 200817 yr can any one tell me if this is normal or a fault ,my wifes sr125 is fine but if you give it full gas from idle it will stall,if you blip a bit first it will rev up no problem,the bike is a 1998 with 1300 miles . many thanks chris.
May 22, 200816 yr is this straight from cold or after warming it up? i know mine would conk out if i gave it too much revs 1st thing on a cold morning...
May 22, 200816 yr If this is happening from cold then it is normal,my dtr stalls at full throtel when cold,let it run for 5/10mins and give it a little throtel evey now and then and then it should be fine.
May 22, 200816 yr Moderator If this is happening from cold then it is normal,my dtr stalls at full throtel when cold,let it run for 5/10mins and give it a little throtel evey now and then and then it should be fine. my mates Gilera does the same (honda engine) till its warm
