sr125 stall on full throttle
can any one tell me if this is normal or a fault ,my wifes sr125 is fine but if you give it full gas from idle it will stall,if you blip a bit first it will rev up no problem,the bike is a 1998 with 1300 miles .
many thanks
chris.
  • 1 month later...
is this straight from cold or after warming it up? i know mine would conk out if i gave it too much revs 1st thing on a cold morning...
If this is happening from cold then it is normal,my dtr stalls at full throtel when cold,let it run for 5/10mins and give it a little throtel evey now and then and then it should be fine.
my mates Gilera does the same (honda engine) till its warm
