Posted March 28, 200817 yr Hello, Does anyone know anywhere which sells complete gasket sets for the 4DL with the 4FU00 barrel? I got a gasket set from a DT125R as its supposed to share the same engine however the generator gasket has a small gap at the bottom. Any help is appreciated.
March 30, 200817 yr Hello, Does anyone know anywhere which sells complete gasket sets for the 4DL with the 4FU00 barrel? I got a gasket set from a DT125R as its supposed to share the same engine however the generator gasket has a small gap at the bottom. Any help is appreciated. Hi there, being as this is the generator side of your motor and shouldn't have any liquid in there anyway it doesn't need to be oil tight or gas tight so it is not a problem !! if it really bothers you just put a bit of instant gasket in the gap to fill the hole?
