kph to mph conversion
hi guys i've just bought a '02 R6. Its a german import and the speedo reads in kph...how would i go about changing it to read mph?
any advice would be appreciated. thanks
You could try something like this:
HERE
Would save you a fortune on changing the clocks :D
Hi mate, hope this helps
1. Turn the key to the on position
2. Press and hold the select and reset buttons at the same time
3. Continue to hold them for 3-5 seconds, it will change from MPH to KPH or from KPH to MPH
It works for me on my 2000 R1 so it should work on yours.
stickers! top idea on a digital clock!!! :blink:
dude its a german import so only shows kph unlike the uk models which do both.
i've found a company that'll make mine into uk spec.
Well if you had said that in your initail post i wouldn't have suggested it would i....and since i have no interest whatsoever in pocket rockets i definately wouldn't have known - only tryin to be helpful you know. :rolleyes:
