Dt 125r wont start!! just backfires!! Help!!
This post is 6077 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi just wondering if anybody can help?
My son was recently given a dt125r, i think its a mid 1990's model, to use as a field bike.
When we got it the carb was missing and the wiring was a mess!!.
I managed to rewire it and i and i bought a secondhand carb, which fitted fine, but when we try to kick start it, all it does is back fire?.
The carb has been stripped and cleaned.
It has a good spark, fresh petrol, new plug, its getting petrol to the carb and to the engine and it has good compression.
Am i overlooking something simple?. As its a been 20 years since i last messed with a 2 stroke.
Also its the model with electronic ignition.
Why it wont start??
checked the reeds?
usually chipped/snapped reeds cause loss of primary comrpession and backfireing.
AYE / SOUNDS LIKE REED VALVE . THEY"R DESIGNED TO STOP BACKFIRE . u said carb was missn, was old reeds still on barrel ?
