Hi everyone! Have taken my 94 tt600r to 2 shops and they can t figure out what s wrong with it.
When it is cold it starts up great and runs until it heats up and then stalls if you rev it up. If it heats up and idles it will run, as soon as you rev it, it stalls.
Carbs have been cleaned, spark plugs checked, all pipes of carb have been changed, valves are polished - don t know - maybe it s the ignition or some electric problem.
Maybe someone can help.
Thank you
Thank you
Looks like a rich cut. The carbs are overfueling on opening.
That was the first thought. But why does it happen only when hot? Dosn t make sense to me.
Thanks anyway
only happens when its hot because it need the extra fuel during warmup. A lean problems gets better as it warms up a rich problem gets worse.
