YX600 Radian...loose wire
jimsmith29841
This post is 6091 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Just bought a 1986 Radian 600......Trailered it home.....I removed the battery cover to remove the battery for a charge. I found this loose connector. It came out near the base of the battery box and has a round connector on the end. It was just hanging loose.
Can you Radian guys let me know where it is suppose to go?
Jim
North Augusta, SC
Link to comment
Share on other sites
Radian 600 uses same running gear as the XJ600 pre diversion. If you follow the wire it should be connected to the earth lead that attaches to the engine, the small lead(should be black) connects to one of the bolts that hold the battery box in
Link to comment
  • Recently Browsing
