March 8, 200817 yr i have a 1981 xs 400 special. i need to adjust the clutch. do i have to take the engine side cover off or is it umder that rubber cap? thanks
March 8, 200817 yr To adjust the freeplay on the clutch lever you just adjust it at the lever itself. Loosen the bigger lock nut and turn the smaller one away from the lever until there is about 2-3mm of space between the lever and the lever holder. If you cannot get the lever to be within 2-3mm you need to adjust the clutch under the rubber cap on the left side of the bike(if you are sitting in the seat). Pop the cap off, loosen the 12mm nut and turn the screw until you feel some pressure then back off 1/4 turn and tighten the locknut. Now you should be able to make the adjustment at the lever. Hope that helps
