February 25, 200422 yr :cry: Hi All My Xj600 Keeps dragging oil up through the airbox and then dumping oil all over the shop. I've cleaned out said airbox and pipes several times but it just keeps going . My local bike shop said "OH they all do that" weel i'd like it to stop anybody got any ideas Cheers Plant
February 25, 200422 yr Moderator I had this same problem once with my XJ550 Seca.......it ended up have too much oil in the crankcase :? ......then the breather tube dumps the excess back in the airbox :!: .....maybe just do a complete oil change with filter, just to be sure? Hope this helps :wink:
February 25, 200422 yr had the same with my old xj600 turned out to be a blocked breather caused by too much oil :oops:
May 14, 200422 yr Hi Plant. Did you get it sorted, if so how? Got the same problem big time......................
November 16, 200421 yr Thank you, thank you. I've had the same problem for ages and couldn't suss it out. You was right, the breather tube was completely blocked, I've sorted it out. Hopefully she'll stop drinking oil and throwing it over everything.
November 16, 200421 yr Moderator Pretty common prob with XJ's :wink: ....@ least it's an easy fix. 8)
