March 6, 200818 yr i have a y reg xj600 pre diversion that will only run when the mixture screw is turned out about 7 times instead of the recomended 2 and a half,any ideas why and what it will do to the engine if i leave it that way
March 9, 200818 yr The recomended 2.5 turns out is only a common starting point, but 7 turns is a lot. I`m wondering if its flooding, has it been off the road for any lenght of time, if it has the carbs may need a good clean.
March 9, 200818 yr Author The recomended 2.5 turns out is only a common starting point, but 7 turns is a lot. I`m wondering if its flooding, has it been off the road for any lenght of time, if it has the carbs may need a good clean. just cleaned them tday cheers but found a corroded inlet rubber mount do u think that might cause the problem
March 10, 200818 yr If it was leaking and letting air in it will put the mixture right out. My xj650 needs the screws turned out 5 turns(2.5 starting point) but it needs new airbox rubbers, i`m expecting they can go in at least 1 turn once fitted, well i hope they will.
March 14, 200818 yr Author If it was leaking and letting air in it will put the mixture right out. My xj650 needs the screws turned out 5 turns(2.5 starting point) but it needs new airbox rubbers, i`m expecting they can go in at least 1 turn once fitted, well i hope they will. i took the carb inlet rubbers off and found one of them corroded i gonna fit a new 1 ojn sunday see if it does the trick,hope so
