I'm cleaning out the green goop and varnish out of these carbs, obviously every jet and orifice is blocked. So I don't damage my pilot jet, can anyone tell me if the hole in the tip of the jet is the same diameter as the holes in the side?
I don't want to try and twist through a wire strand that will open the hole up too large.
Thanks again
Thanks again
I've had loads of probs with the tips of the adjuster snapping off by heavy handed butchers.
so i have had to drift out the needle tips thus opening up the jet.
not had a problem with slow running as the new needles can close up and compensate for the amount of widening
hope that helps
edit: i hope we are talking about the pilot system situated top front of the carb via the pilot screw!!
Actually, I was referring to the pilot jet that is covered by the rubber plug. It’s right next to the main jet.
thanks
thanks
Not sure about the size on them, but you should be able to take them out and soak them in carb cleaner to get them clean. I actually have used a straw from a broom to clean orifices out without damaging them as the straw is tough enough to help clean the stuff out but soft enough not to damage the brass.
