was setting about a roller change earlier when i hit a problem
the belt won't stop turning wen i turn the bolt
any helps on how to stop this or actully how to change them?
you gotta lock something up-never done variator rollers, but for example if i wanna take the front sprocket nut off on a chain bike, i stick a piece of wood through the wheel, so the chain and wheel and sprockets cant turn and then i can undo the nut.
Guess you gotta find a way to do something similar
Try logging onto www.leroybeal.net/motorcycles/drivepulleytool
That should put you on the page.
Also try scootdawg.com lots of good info and pictures on changing variators and etc.
Let me know if you can't find the sites..
That is two different ways to make a good variator removal tool..
just done them today...runnin sweet naw ;)
cheers for the hand :)
Thumbs up,,Keep em Flying !!! :)
