March 4, 200817 yr was setting about a roller change earlier when i hit a problem the belt won't stop turning wen i turn the bolt any helps on how to stop this or actully how to change them?
March 5, 200817 yr you gotta lock something up-never done variator rollers, but for example if i wanna take the front sprocket nut off on a chain bike, i stick a piece of wood through the wheel, so the chain and wheel and sprockets cant turn and then i can undo the nut. Guess you gotta find a way to do something similar
March 8, 200817 yr was setting about a roller change earlier when i hit a problem the belt won't stop turning wen i turn the bolt any helps on how to stop this or actully how to change them? Try logging onto www.leroybeal.net/motorcycles/drivepulleytool That should put you on the page. Also try scootdawg.com lots of good info and pictures on changing variators and etc. Let me know if you can't find the sites..
March 8, 200817 yr Try logging onto www.leroybeal.net/motorcycles/drivepulleytool That should put you on the page. Also try scootdawg.com lots of good info and pictures on changing variators and etc. Let me know if you can't find the sites..
