Posted March 3, 200817 yr Hey all, my R6 has developed a rattle on tick over, it sounds like a you are shaking a bolt in an empty tin can (probably not as quite as bad as that to be fair)! As soon as the revs pick up it goes it's just on idle? It's difficult to say exactly where it's coming from but is certainly not affecting the riding or performance. Any ideas?
March 3, 200817 yr Hey all, my R6 has developed a rattle on tick over, it sounds like a you are shaking a bolt in an empty tin can (probably not as quite as bad as that to be fair)! As soon as the revs pick up it goes it's just on idle? It's difficult to say exactly where it's coming from but is certainly not affecting the riding or performance. Any ideas? hi there/ sounds like small end bearing . but get a pro. to listen to it . will run like that for awhile. wudna panic.
March 4, 200817 yr More likely to be cam chain tensioner. they go quieter once the revs rise as faster chain speed throws a bigger arc and takes up the slack. Get some one who`s good to have a listen before too many more miles, if whatever it is lets go it could be very costly once its gone totally tits up. And you do not want it to let go at 13000 revs!
March 5, 200817 yr More likely to be cam chain tensioner. they go quieter once the revs rise as faster chain speed throws a bigger arc and takes up the slack. Get some one who`s good to have a listen before too many more miles, if whatever it is lets go it could be very costly once its gone totally tits up. And you do not want it to let go at 13000 revs! Agree with the first reply, but may also be be your starter motor? Which would be the best place to start i think? Could be the spring that is not retracting the the cog? Regards Stacy R6 MPJ
March 5, 200817 yr dont know about R6s, btu the 1002cc exup engine is rattly at idle due to the starter chain and theres very little can be done apart from a rebuild-but its not serious anyway, just makes the bike sound a bit shit.
March 5, 200817 yr cam tensioner is what im going for too. had many r6's and all have the fault simple to fix thank god.
March 6, 200817 yr Author Thanks for your suggestions, I'm popping into my Yam dealer on Saturday and will let you all know. Should have started a sweepstake!!
March 6, 200817 yr I1ll have a £1 each way on the cam chain tensioner R1evad ; if u lose bet u gota ride thru herts naked at midnight. WE ALL WAITING THE DEALERS REPORT NOW
March 7, 200817 yr Author R1evad ; if u lose bet u gota ride thru herts naked at midnight. WE ALL WAITING THE DEALERS REPORT NOW HAHA, whatever the dealer says to me i'm tempted to say it wasn't the Cam now!
March 12, 200817 yr You do know that evad is DAVE spelt backwards Me doing anything naked is a sight sure to scare the horses and children, let alone riding through the County Will be pleased to hear the fault is something minor all the same
March 13, 200817 yr Author A bit of a disappointing end to the mystery rattle guys, the mechanic gave the whole bike a once over and said there is nothing wrong with it at all but he couldn't tell me what was causing the rattle, all my suggestions as to what it could have been (with the help of you guys) he dismissed! R1evad your modesty remains in tact.
March 13, 200817 yr Well for my two pennyworth, I would say that a tappet has come loose or is sticking.
March 13, 200817 yr A bit of a disappointing end to the mystery rattle guys, the mechanic gave the whole bike a once over and said there is nothing wrong with it at all but he couldn't tell me what was causing the rattle, all my suggestions as to what it could have been (with the help of you guys) he dismissed! R1evad your modesty remains in tact. BOO HISS Had planned a trip to Hants this wkend ur out of jail Dave And sounds like cud b that tapit right enuff. [ not bettin tho might end up like R1EVAD. ]
March 14, 200817 yr Right what you do now is buy some new oil (try a slightly thicker grade) and a filter, take the bike out at the weekend and get it really hot. A tankfull at full chat should do it Get back home, change the oil and filter, (mind you don`t burn your hands) then run it up, if it was anything a bit sticky that will probably cure it, if makes no difference, at least you`e got you oil sorted for the summer I`ll get me coat
