February 27, 200817 yr i have currently put some new boyson reeds in my Yamaha aerox and it goes off the clock on flat land but i want to go faster any suggestions ??????????
February 27, 200817 yr Throw yourself off a tall building - if you point your head at the ground you should get in excess of 150mph before it begins to hurt!
February 27, 200817 yr just off the clock? riite well here'sa bit of my old setup malossi 70cc big bore...rebored to 80 malossi mhr (i think) pipe 3.6g's rollers (no fancy kit) k&n style filter 21mm carb new crankshaft de-restricted cdi unit few more, don't remember really just a standard engine now with a technigas next-r pipe..enuff fun still to be had
February 27, 200817 yr Throw yourself off a tall building - if you point your head at the ground you should get in excess of 150mph before it begins to hurt! lol seriously why did i spend on mine? never again!
August 24, 200916 yr i got an aerox 2001, i found the best mod i could buy was a 70cc kit from pm tuning and a full circle crank, cost me around £200, and u already got the inlet so a bigger carb helps alot too, i havent passed my test yet but i have taken it out once or twice and i i got it all the way back round to 10mph on the clock going up hill!!! and it im not carefull40-65mph it just wheelys, good fun though.
August 25, 200916 yr How fast do you want to go? Buy a pre-2000 Hayabusa and go all the way up to 215mph, apparently... You'll need about 4 miles of clear road in front of you to do that safely, though. Thing is, naked bikes feel much faster. Rip off all your bodywork and, while you won't be going that fast, it will feel like it.
