February 22, 200817 yr hi all, new here...... looking for some help if possible. the accelerator on my xt125x (07 plate) has become stiff and hard to twist. after like, 10 minutes my wrist and arm really hurt and become numb. i have tried wd-40ing everything i can see to no avail! any ideas? thanks
February 22, 200817 yr Moderator hi all, new here...... looking for some help if possible. the accelerator on my xt125x (07 plate) has become stiff and hard to twist. after like, 10 minutes my wrist and arm really hurt and become numb. i have tried wd-40ing everything i can see to no avail! any ideas? thanks sounds like the cable is dry. you need to buy a cable oiler and use it. Just check the cable is not chafing under the tank etc and this can let water in a rust the cable making it stiffer.
February 24, 200817 yr Author sounds like the cable is dry. you need to buy a cable oiler and use it. Just check the cable is not chafing under the tank etc and this can let water in a rust the cable making it stiffer. hi thanks for advice, ill try that
February 24, 200817 yr Author hi thanks for advice, ill try that yep, i pulled back the cable cover next to the throttle, and lo and behold, lots of gungy crap on the cable! thaks for the advice mate, i even had the bike booked in to yamaha! youve saved me a few days without my bike!
