knowledge boy Posted February 21, 2008 Share Posted February 21, 2008 Hi all, my horn has decided to work intermittently when revs are at a certain point the horn seems to work. also my starter motor seems to have packed up. My lights all work perfectly and the battery is fully charged!! Could this be an alternator/generator problem? Again thanks in advance for and advice offered!! Chris Link to comment Share on other sites More sharing options...
eire_kp61 Posted February 21, 2008 Share Posted February 21, 2008 if your battery is definatly fully charged then it sounds to me like you got a bad earth or loose connection because if you have full charge in your battery the horn would work your starter problem is down to the same bad connection id say Link to comment Share on other sites More sharing options...
