more problems with my neo's
Hi all, my horn has decided to work intermittently when revs are at a certain point the horn seems to work. also my starter motor seems to have packed up.
My lights all work perfectly and the battery is fully charged!!
Could this be an alternator/generator problem?
Again thanks in advance for and advice offered!!
Chris
if your battery is definatly fully charged then it sounds to me like you got a bad earth or loose connection
because if you have full charge in your battery the horn would work
your starter problem is down to the same bad connection id say
