Cam Posted February 20, 2008 Share Posted February 20, 2008 Hi everyone first time on hear and I need the help. I have a 1999 600 FAZER I use it to commute every day (12 miles each way) Yesterday the speedo,the rev counter the tacho meter all started working intermittently the speedo winding all the way round or siting on zero, however, when I operated the brake lever the gauges jumped al over the place the bike has never exibited this fault before and switching it off and restarting seemed to cure it. The battery was flat a couple of weeks ago but I recharged it satis please help. Link to comment Share on other sites More sharing options...
Dave C Posted February 20, 2008 Share Posted February 20, 2008 I would start with the earth leads, had a similar problem on my old xj, pressed starter button and the tacho went crazy. It turned out to be bad earth connections. Link to comment Share on other sites More sharing options...
Live to ride Ride to live Posted February 20, 2008 Share Posted February 20, 2008 Hi everyone first time on hear and I need the help. I have a 1999 600 FAZER I use it to commute every day (12 miles each way) Yesterday the speedo,the rev counter the tacho meter all started working intermittently the speedo winding all the way round or siting on zero, however, when I operated the brake lever the gauges jumped al over the place the bike has never exibited this fault before and switching it off and restarting seemed to cure it. The battery was flat a couple of weeks ago but I recharged it satis please help. Yes this does sound like an earth issue, check all connections in and around ins panel, you may need to remove to see it, dodgy wire somewhere vibrating when moving,hense your instruments going wonky, when sat, no vibes,hense working. Let us know how you get on. Link to comment Share on other sites More sharing options...
Live to ride Ride to live Posted February 20, 2008 Share Posted February 20, 2008 Arse, double post!!! sorry. Link to comment Share on other sites More sharing options...
