February 13, 200818 yr riite i need help! my aerox, oil plug/sump fell out oil everywhere the thing i need to know is do i: 1. put it back in as it is or 2. have to take it to a garage because it has to be re-sealed? help...please
February 14, 200818 yr Did it come undone, because it wasnt tight enough, (who put it in last time?). If so put it back in, do it up properly and refilL the sump. Or are the threads wankered, in which case who did it up TOO TIGHT, or cross threaded it last time? If threads are damaged, get the bike to a decent mechanic who should be able to retap or helicoil the sump and fit a NEW PLUG. LET US NOW HOW YOU GET ON.
February 14, 200818 yr Author i've took all the fairing off this morning seems to have simply just come out so i'm gonna try n push it back in and put some oil see if it holds i'll update u later thanks
February 14, 200818 yr Author split in the tank ordering new 1 in the next hour or 2 do i need to re-bleed the oil pump or anything when changing it?
February 20, 200818 yr Author yep tank arrived this morning (slow ebay) getting it all done by the weekend found a local guy with bike knoledge said he'd do it for £15 £20 less than the local bike shop wanted
