riite
i need help!
my aerox, oil plug/sump fell out
oil everywhere
the thing i need to know is
do i:
1. put it back in as it is
or
2. have to take it to a garage because it has to be re-sealed?
help...please :)
Did it come undone, because it wasnt tight enough, (who put it in last time?). If so put it back in, do it up properly and refilL the sump.
Or are the threads wankered, in which case who did it up TOO TIGHT, or cross threaded it last time? If threads are damaged, get the bike to a decent mechanic who should be able to retap or helicoil the sump and fit a NEW PLUG.
LET US NOW HOW YOU GET ON.
i've took all the fairing off this morning
seems to have simply just come out
so i'm gonna try n push it back in and put some oil see if it holds
i'll update u later
split in the tank :(
ordering new 1 in the next hour or 2
do i need to re-bleed the oil pump or anything when changing it?
did ya get it all sorted?
shouldnt need bleeding, just fill `er up.........
yep
tank arrived this morning (slow ebay)
getting it all done by the weekend
found a local guy with bike knoledge
said he'd do it for £15
£20 less than the local bike shop wanted :)
