Ok guys I am new here so hello.Just a little info.I was given a 1998 yzf 600r from the original owner after it was stolen. It sat for a year and I brought it home. I hooked it on a charger and it fired up pretty quick.That was a month ago.Now it sits on stands with the fairings and wheels off due to getting plastics painted soon. Ok I got a new ignition switch after the original had been drilled out. Hooked everything back up and it would only turn over.The fuel pump would not kick on. There was no voltage getting to the fuel pump. Some guys said it may be the Starting circuit cutoff relay. Ordered a used one and now the fuel pump still won't kick on. Could it be the starter solenoid? I checked the plug that goes to the starter solenoid and the top two have voltage but not the bottom two. Thanks for all the help
