Posted February 9, 200817 yr Please help! R6 06, when i start it up sometimes its starts no probs and other times it starts and dies instantly, So i try again and i have to start it and hold on the revs otherwise it dies again. After a few seconds of revs its ok and will tick over...Its intermitent and doesn't do it all of the time. Its like it cant be bothered to start and tick over!!!
February 9, 200817 yr This could be dirt in the fuel system or a problem with the tacho sender to the fueling computer. Check the throttle position with the throttle bodies.
February 10, 200817 yr Author This could be dirt in the fuel system or a problem with the tacho sender to the fueling computer. Check the throttle position with the throttle bodies. Yeh thanks i'll check that out...if it wasn't that and there is a problem with any of the electronics what signs am i lookin for on the checking system when i turn on the ignition..??
February 22, 200817 yr HI MATE MINE DOES EXACTLY THE SAME! WHEN STARTING PULL CLUTCH IN AND JUST PRESS STARTER BUTTON DO NOT USE ANY GAS AT ALL IT WILL START UP NO PROBLEM AFTER THIS JUST LET THE THING TICK OVER FOR THIRTY SECONDS OR SO BEFORE TRYING TO REV IT, I THINK THE BIKES COMPUTER SYSTEM LIKES TO CHECK EVERYTHING OUT AND IF YOU USE GAS WHILST STARTING OR THE FIRST THIRTY SECONDS IT WILL CAUSE IT TO DIE AND LIKE YOU SAID WHEN YOU GO TO KICK HER UP AGAIN YOU HAVE TO USE MORE GAS OR IT WILL DIE AGAIN TRY LIKE I SAID ABOVE AND YOU WILL NEVER HAVE A PROBLEM JUST LOOK AT IT AS THE BIKE IS JUST SETTING ITS SELF UP SOMETIMES FRUSTRATING BUT AT LEAST THE OIL WILL GET ALL ROUND THE ENGINE BEFORE A GOOD RIDE! REGARDS R6DYS
